05-01-2012, 10:16 AM | #1 | ||
Next upgraded Mk1 Leopard
Bugger. I have done some touch up repairs on the AU over the past few days. Mostly stone chips. But I had 1 large scrape on the bottom of one of my side skirts that I thought I would spray. I had some Monsoon Blue in a can and some clear finish. Now I know that Monsoon Blue is a 2 Pac paint so I was a good boy and sprayed it on lighlty, wet sand between coats (1500 and 2000 paper) and left for a day after I had covered the scrape. I then did 5 coats of the clear and again waited 24 hours before cutting back. Well it is nice and smooth but the clear is still milky. What have I done wrong? I was going to re spray the rear spoiler but now I think I am going to have to spend some $$$ and get it done by a pro. UK
05-01-2012, 10:54 AM | #2 | ||
Resident AFF detailer
Pictures?
No longer an 'active' detailer. |
05-01-2012, 01:57 PM | #3 | |||
and and UK
05-01-2012, 02:02 PM | #4 | |||
AU DIE HARD
Bigest headache with that is the clear, it needs blending clear to make it blend in , very hard to achieve with a part panel from a can , you can just top coat the blue and polish it with out a clear coat, for the area your doing it would be fine , or you could just do the whole panel but it will probabley peel if it gets chipped again. or maybe get the paint shop to mix a can with some clear added.
05-01-2012, 03:34 PM | #5 | ||
Critical Thinker
Wouldn't it need to be buffed after it cures too? That's gotta help with the frosty appearance surely?
"Everybody was KungFu fighting..." 2022 Mazda CX5 GTSP Turbo 2024 Ford Everest Trend 1967 Ford XR FALCON 500 Cars previously owned: 2018 Hyundai Santa Fe Highlander 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
05-01-2012, 03:40 PM | #6 | ||||
AU DIE HARD
05-01-2012, 04:50 PM | #7 | |||
05-01-2012, 06:36 PM | #8 | ||
Thanks guys. I was told as it was that I had to go over with clear to get the shine effect like 2 Pack (which I can't get in a spray can). This is correct?
UK
05-01-2012, 06:55 PM | #9 | ||
Critical Thinker
you can get clear coat in a can. But the application of the clear coat wont be as neat and crisp as it would be off a gun.
05-01-2012, 07:01 PM | #10 | ||
Clearcoat will give the finish it's depth and gloss. When using a spray can - VERY VERY light and thin coats...
It may well be worth seeing if a mobile paint repairer can assist with this...they should be able to do a 'mini-respray' of just the affected area, and they can make sure it blends pretty well also.
05-01-2012, 07:04 PM | #11 | ||
AU DIE HARD
I would ask your local paint shop if they can do a mix in a can for you 75 /35 would do on the small part your doing, or there's a compressor and some dusty old guns and gear in my shed
06-01-2012, 08:41 AM | #12 | |||
75 paint 35 clear? UK
06-01-2012, 09:31 AM | #13 | ||
Rapid temp change or very cold panel will cause this. On a touch up area I personally would not have used a clear coat.
cheers Keith |
06-01-2012, 10:24 AM | #14 | ||||
AU DIE HARD
Yes thats the basic idea, not even sure they would do it for you , The basic theroy with Acrylic Paint I was taught back in the day (pre 2 pac dinasour days) was cover the repair with the base colour , usally 3 coats , followed buy 2 complete coats of colour . then a 50 50 mix of colour and clear,2 coats, then 75% clear 25% paint, 2 coats, then 1 or 2 coats of straight clear, works fine for large repairs or just scale it down for smaller jobs, the problem with metalics if your using a clear coat you have to blend it into the existing part of the panel which involves spraying a blending clear on to the good surface to get the paint to flow on from the repair . It can get bigger than Ben Hur, which is why I wouldn't use a clear over the top on a small repair
