Old 18-10-2009, 06:44 PM   #1
Halfmo Rocks
Bearded Hermit
Default crazy needles
while doing my cleaning rounds, i got a dead moth out from the between the plastic screen & instruments, i think i must have bumped something i shouldn't have...the tacho now sits almost pointed directly down when turned off, and both speedo & tacho do a crazy dance twitching without moving far upon turning on or off ignition.
tacho does seem to work fine...but at needle showing lower revs than should be...seems to fit with how much lower it's of position is now
did i break my cluster? anyone know what the hell i did?
Halfmo Rocks is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2009, 06:57 PM   #2
falzoony
Rockin '67
falzoony's Avatar
Mine did the same thing when I put in my white background on my cluster. It took a while to fix for me. I had to keep taking the needle off and putting it back on untill it was in the position. It was a while ago and that is all I can remember from my experience, hope it helps you.
BA XR6 Turbo
'67 XR Wagon
falzoony is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2009, 07:40 PM   #3
Halfmo Rocks
Bearded Hermit
do the needles just pull off or is there a trick to it?
Old 18-10-2009, 07:43 PM   #4
falzoony
Rockin '67
falzoony's Avatar
Yeah they just pull off but you have to be really careful because they are held on by a very thin wire. Maybe an idea to use 2 small flat head screwdrivers to pry them up.
BA XR6 Turbo
'67 XR Wagon
Old 18-10-2009, 08:24 PM   #5
Halfmo Rocks
Bearded Hermit
sweet...i'll give that a try
Old 18-10-2009, 11:16 PM   #6
aye you
The Origional, The Best
aye you's Avatar
found mine came off real easy by rotating them counter clockwise while pulling them towards you.
mine have done the same. been told the rotating them counter clockwise until they show 0 when the car is off will/should fix the problem
Current Mods
2.5" Red Back Exhaust | C2R Grill | Brumby Front Bar & Driving Lights | 18" Optic Blacks | Tickford Intake | Blue Momo Shifter Knob & Wheel | BA Scuff Plates with Ford Metal Inserts
Future Mods
Lowerage on KingSprings Lows | Engine...Period | Sounds System
I Use And Recommend F1 Tyres And Wheels On The Gold Coast
Proud Supporter of Beat The Heat (NT)
aye you is offline   Reply With Quote Multi-Quote with this Post
Old 19-10-2009, 07:09 AM   #7
Halfmo Rocks
Bearded Hermit
kind of works that way...got it done last night.
think i got it sussed, with needle halfway off you can turn it counter clockwise to get into right position : takes a bit of fiddling, but she looks cool now. won't know for sure until i drive to work soon - but the needles aren't crazy dancing anymore.
thanks for the help falzoony, appreciate it mate
Old 19-10-2009, 07:56 AM   #8
BIGJB
BIGJB's Avatar
That was how I did mine. Works a treat.
BIGJB is offline   Reply With Quote Multi-Quote with this Post
Old 19-10-2009, 04:35 PM   #9
Halfmo Rocks
Bearded Hermit
all good now...everything working great...& i learned how to do something else to my car - cool
Old 19-10-2009, 06:13 PM   #10
falzoony
Rockin '67
falzoony's Avatar
Glad I could help mate
BA XR6 Turbo
'67 XR Wagon
