After some delays in getting my Advantage 3 dealer software upgrade and the necessary hardware compatible with the LS/LT/LV Focus I was able to put a tune in it yesterday.
The results - a massive increase in midrange torque. Torque steer is evident with TCS switched off, with the car quite happy to wheelspin 2nd gear when the throttle is flattened. The engine revs up very quick, but runs out of puff by around 5500-5700rpm. I say it's a limitation of the stock turbo charger. Small turbo = great low down response with quick spool up at the expense of top end power. Oh well, nothing a manifold and GT25/28 upgrade can't take care of ![]() No dyno results just yet, I've checked AFR's with my wide band sensor with it showing good fuelling. I'll get the car to a dyno soon to see the difference in power/torque/boost between this tune and the stock one. Not that I really need to though to tell me what's going on - the boost gauge sits just shy of 1.2bar and the engine pulls like all heck. The programming of these ECM's is very different to the Falcon/Territory programming. There's a huge amount of torque control and throttle control limiting power and boost. A quick remap fixes this. Programming the ECM is time consuming, with the first ECM read to suck the factory tune and store it in the XCal 2 device taking around 45 minutes ![]() ![]() So there you have it. One programmed LV XR5T. I'll post dyno sheets when I get it on a dyno. A quick plug to Street Tuner for his assistance and Matt from BP Racing.
2021 BMW M550i in Black Sapphire Metallic.
11.52 @ 120mph stock |
Knows nothing. Apparently
If you get onto the www.fordxr5turbo.com forums and search for an " ECU spacer" that should fix the reknowned 5k flat spot. Can't talk from personal experiance yet but there's 11+ pages of guys raving about the results. Plus they're sourced from one of the forum members and it'll only set you back 50 beans!!
As for the ecu reprograming, what made you do it that way?? Most guys I know use a Dreamscience unit or something else similar. Plug in, wait 2-3 mins, unplug and your doneski, apparently with phenominal results. Haven't done it myself yet (I've only had the car 3 weeks) but it sounds good.
2008 Electric Orange LV XR5. With dreamscience strategem SCT, K&N 57i Gen2 cold air intake for more fun and demonic vaccum cleaner noise!! ![]() 1975 Mitsubishi/Chrysler GC Galant 2-door Hardtop. 4G63 DOHC heart transplant nearly complete!
Check out the build over here |
I've already fitted the ECU spacer, I believe the fall off in power over 5500rpm is caused by loss of boost. However, it is still making more power than stock at that point.
Why reprogram it myself? I'm already a SCT dealer, so why not be able to do the focus as well as the other vehicles I do ![]() It's only the initial ECM read that takes a while, once done changing tunes via the hand held programmer only takes 2-3 minutes like you suggested.
TVS Super Pursuit
How would this go on the XR5 Mondeo (2008 Model)? It comes standard with a different tune. |
Fair enough.
I was getting a DIY vibe going on. ![]() Has the spacer made a difference at all?? obviously you're keeping a close eye on gains you've made and i'm curious to hear from someone else what it's done.
#6 | |||
With any luck I'll have it on the dyno early next week.
