05-06-2005, 08:57 PM | #1 | ||
Has anyone fabricated (or is there one available to buy) a cover that goes over the radiator reservoir in EA - AU Falcons??
Ford had one in that bronze orange supercharged 6 Predator EL showcar some years back and it looked pretty good.. well it looked better than the yellowed dirty plastic one in my car!! any other suggestions to make it look better as its a bit of an distraction to the eye! cheers |
07-06-2005, 12:06 AM | #2 | |||
Walking with God
If you did cover it up, how would you see what the coolant situation is like? George |
07-06-2005, 12:09 AM | #3 | |||
they call me Tibbo
I made one out of stainless steel for a friend, I'll see if he can get me some pictures of it...
07-06-2005, 12:24 AM | #4 | ||
bolts on's
PWR make an polished alum header tank which replaces ur plastic one , mind u its not cheap but they do look great :
07-06-2005, 04:05 PM | #5 | |||
Yep this is along the lines of what I was thinking of.. i've got very little experience in metal work, did you just bend the metal into shape, cut it with snips and then file off the sharp edges? i check the condition of the coolant enough by taking off the cap so no probs in not being able to glance at the level on the side |
07-06-2005, 05:14 PM | #6 | ||
they call me Tibbo
Yea sort of, i might still have the diagram i used floating around here somewhere.. It was only a cover... If you are interested I'll do a quickie (as I wouldn't mind one on my car) .. I guess I could make a tutorial while I'm at it...
Ohh and you can still see the water level where the low coolant sensor lives if it isn't fitted to your header tank Tools you'll need :- Grinder with a cutting wheel Hacksaw or snips Ruler Drill Round File Something to bend it over, and if your super keen a TIG welder but that is only if you wanted to weld the ends up when your finished...
07-06-2005, 07:59 PM | #7 | |||
Walking with God
Anyway each to their own. All the best with the mod. |
07-06-2005, 10:46 PM | #8 | ||
thanks Racecraft if your happy to do a tutorial, i'm keen to give it a go.
this is a link to the predator in case people dont know what i mean.. http://www.trueblueford.com/ELpredator_Showcar.html why didnt ford ever make this by the way??? |
08-06-2005, 10:29 PM | #9 | |||
LIFELONG DJR SUPPORTER
I check all the vitals under hood when low windscreen washer level light shows, otherwise the bonnet stays shut! : What a car! Cheers, Mike |
10-06-2005, 12:12 AM | #10 | |||
Walking with God
The gas apparently plays havoc with the ignition being altered in failsafe mode. |
