Old 19-07-2007, 08:06 PM   #1
GTS_300_Coupe
Mandy Moore FTW!
GTS_300_Coupe's Avatar
Default Amber coloured front indicators on EF/EL?
Does anybody know if there are amber coloured front indicators available for the EF or even EL falcons?
You know the clear part that sits beside the actual headlight?
I want a similar look like this on my EF:
EDIT: Sorry guys hopefully the pic works now.
GTS_300_Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 19-07-2007, 08:08 PM   #2
XR_Lightning
Riding The Lightning
XR_Lightning's Avatar
link not working mate
ED XR6 - T5 - 1521a@112 - 3.9's - 170.2rwkw - POWERED BY METALLICA
XR_Lightning is offline   Reply With Quote Multi-Quote with this Post
Old 19-07-2007, 08:10 PM   #3
LUXO_8
windsor user
as above, link not working.....but from what i can gather you're asking if EF/EL's had an amber indicator lens like EA-ED's did...........if thats your question then no, they're all clear lenses
Old 19-07-2007, 08:26 PM   #4
fordzatmyplace
B Series XR8 Pilot
what i suggest you do is pull the original EF/EL indicator apart, as in taking off the lense, and paint the inside the indicator housing orange and the put it back together, it will give you about 90% the same look as in that pic
Is that a BULGE on your bonnet? Or are you just happy to see me?
WANTED EB-EL V8!!
http://www.fordforums.com.au/showthread.php?t=11242992
fordzatmyplace is offline   Reply With Quote Multi-Quote with this Post
Old 19-07-2007, 08:29 PM   #5
pauly85
commodore bogan
pauly85's Avatar
and if your ef/el is like nearly every other one on the road, the lense should just pull off with slight pressure, i cannot count how many indicator assembly's i have re-glued back together, or just replaced entirely
BA RTV
pauly85 is offline   Reply With Quote Multi-Quote with this Post
Old 19-07-2007, 08:47 PM   #6
MIEF9640
MIEF9640's Avatar
Default Amber Len's
They are actually meant to run the amber globes in them that are readily available from all motor spres stores.
MIEF9640 is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2007, 12:09 AM   #7
DEVL-XR
EBII XR6
DEVL-XR's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Writing tech article(s)
Question is why would you want amber indicators, even if it is on the inside. You do that and you'll be taking 10 steps backwards in making your car look nice.
On a side note I'm in love with that red Mustang!
DEVLXR
DEVL-XR is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2007, 12:13 AM   #8
LUXO_8
windsor user
ok.. from the pic, the lens is clear and its either running an amber filter inside or just the amber globe reflecting off the reflective surface....
if you removed the lens, and removed the inner lens, then added an amber globe, you'd get the desired look
