For those who have changed rear rotors, did you guys use a deep socket to get the nut off the hub thread? Anyone know whats size socket (mm) it is?
I think from memory you just undo the countersunk screw and belt the old rotor off,ive got the 3/4 drive imperial socket size if you need me to check it i can if you want to remove the hub.
T3 Hardcore |
Yeh i removed the screw and i tried whacking the rotor and levering it with a bar and the rotor wasnt budging. So i thought the pack nut was holding it in and didnt have the tools to get it off at the time. So i just put it back together to do another time.
Il just have to put a bit more muscle into it if by the sounds of things ![]() |
T3 Hardcore |
#5 | |||
Performance Inc.
Might need to back off the hand brake as there may be a bit of lip iside holding it on.
In The Garage... ![]() FPV Super Pursuit Build no 0080/91 Lotus Exige S/C S240 Kart Hasse Chassis 100J Power Quote:
The rotor rusts onto the hub. You need to soak it good with Rost-off or similiar. Then get under the car with a lump of 3x2 hardwood and a big hammer
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust. AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl OWN THE ROAD |
thanks alot guys! Appreciate the help, looking at that thread now.
Thread Tools | |
Display Modes | |
