09-03-2008, 01:44 PM | #1 | ||
I bought a new radiator a few months back and through my own stupidity managed to puncture one of the side tanks. I brought it to a local rad place and the guy patched it up, but it's leaking again now. I have 2 options available to me right now.
1. Have the side tank repaired - I can't remember the exact cost but I think it was $70 odd. 2. Buy a new radiator. Obviously I'd much rather save the cash and have a new tank put on it, but if it's just going to start leaking again, would I be better off just buying a new one and being more careful with it this time and possibly selling the damaged one? I'm looking your way Blueprint Everyone's input is welcome. Thanks for your input. |
09-03-2008, 02:29 PM | #2 | |||
one can be soldered and the other glued with high temp epoxy but in the mean time drop a raw egg in a cold radiator and go for a drive of at lease 20 minutes. |
09-03-2008, 06:44 PM | #3 | ||
They're plastic tanks on the side. If it's gonna just be glued in, what are the chances of it holding up better than the patch job that was already done?
09-03-2008, 11:06 PM | #4 | ||
when i had my ea, i had a similar problem, except the tank had basically worn out lol....anyway, i took it to natrad and they pulled the old tank off, flushed it and put a new one on, i think it was about $60 but that was a few years ago now, so it should be possible, good as new afterwards
10-03-2008, 01:30 AM | #5 | ||
If you want to patch it yourself use JB weld. http://jbweld.net/products/jbweld.php
not cheap but it is the next best thing to getting a new tank or radiator (which I would recommend you do).
regards Blue |
10-03-2008, 12:10 PM | #6 | ||
Sales Representative
Forget the bloody glues and plastic welding, none work and i should know... tried everything on the market with all failing in service... plastic welding will not work due to the material type, Polymide 54 from memory... it has Fibreglass through it, and has such a high melting range, it can burn before it melts... i am also a plastic fabricator, so i've tried...
Get a replacement tank, but go the ADRAD way...
Project InfernoSR - Back Burner Project FeralTerra - No longer Project Fairmont Prodigy - Sold Thanks go to: MY WIFE! Bathurst Brakepro Undacar eBay!! |
10-03-2008, 12:52 PM | #7 | ||
What sort of price am I looking at for a new tank? I think I was told about $70 the first time but can't remember exactly.
What are the chances of the new tank failing? Is it just as strong as the old or will the seam where it meets the radiator be weaker and prone to leaks? Thanks. |
10-03-2008, 01:29 PM | #8 | |||
10-03-2008, 02:05 PM | #9 | ||
Well its an ADRAD copper core, which of the types you mentioned is it more likely to be?
10-03-2008, 03:05 PM | #10 | |||
10-03-2008, 05:35 PM | #11 | ||
Thanks for that blueprint. You're a legend. I'll take it down to the local adrad place this week. Does $70 sound about right to you?
10-03-2008, 05:36 PM | #12 | ||
To be honest, its pretty cheap... normally around the $140 from us, but thats a full service, 2 new seals, complelty cleaned and repainted...
10-03-2008, 05:39 PM | #13 | ||
Well this radiator is only about 3 months old. Does that make a difference? Like I said, I can't remember the amount I was quoted.
If it's going to be $140, I'll probably just pick up a new one for $220... EDIT: I'm guessing that price would include you having to pull the radiator from the car? If so, I'd be doing that part myself, so all that would have to be done is replace the tank. |
10-03-2008, 05:56 PM | #14 | ||
Just remember 1 thing... we are in the bush, freight is a killer...
If its only 3 months, then i'd do it cheaper... i'd look at around that price for only a tank change and external cleaning.
10-03-2008, 06:22 PM | #15 | ||
70 or 140 ?
10-03-2008, 06:35 PM | #16 | |||
huh???
10-03-2008, 06:47 PM | #17 | ||
I'm in the south east. Essendon is a bit of a hike. I don't know if I'd be able to get anyone willing to give me a lift all the way there. What sort of prices am I looking at if I brought the car down there (not just the radiator)?
10-03-2008, 06:51 PM | #18 | ||
huh???
i cant remember off the top of my head but i can look into it and get back to you ill also get a price on a new tank if you are interested i may be also able to come and fit it myself..
11-03-2008, 12:03 AM | #19 | ||
You can purchase a brand new AU6 radiator in moorabin for $130. cash. PM me for the details.
11-03-2008, 08:25 AM | #20 | |||
13-03-2008, 06:07 PM | #21 | ||
I'm bringing the radiator down to the NATRAD place tomorrow. Some of the transmission fluid leaked out of it, a few hundred mils. Am I going to have to top it up or is it nothing to worry about? It wasn't a problem last time as I got a service done on the transmission a few days later.
If I do have to refill it, what type of fluid am I going to need and how do I get it in? |
13-03-2008, 06:08 PM | #22 | ||
Good to hear you are taking to a proper place radiator place :P as for the fluid... just match what was put into it at last service and ask them how to top it up :P
13-03-2008, 06:25 PM | #23 | ||
Will the amount lost be a problem? Is it alright to mix different brands of fluid? I could give the trans place a call but they'd probably tell me to bring it in and charge me for it :(
13-03-2008, 07:42 PM | #24 | |||
13-03-2008, 08:25 PM | #25 | ||
What type does it take normally? Did a search and it says TQ95 or 95LE. Which should I buy and is it alright if the two are mixed?
I also read that the tranny is sealed because people were putting Dextron III in there. If the trans place was to have put that stuff in, is it still alright to mix? |
Thread Tools | |
Display Modes | |
