Let's play Dodgeball!
Does anyone know where I could get a driver's side mirror for an EF Falcon Futura? I've been ringing around and it seems only possible to get the whole thing replaced and because Futura have body coloured mirrors, I'd have to then get it painted. This is looking at setting me back $170 (including 50 to get it painted)
I'm a pov student, so I dont have this much spare money lying around. I would greatly appreciate if anyone knew where I could just get the mirror part (drivers side) Or if there are any spare light blue side mirror sets out there?...that arn't too expensive. any information or places that you know of that might be of help to me, would be greatly appreciated. :voldar02: Thanks again Lisa |
Low and Loud
What wreckers have you tried in your area?
Jolly Rodgers in Dandenong would most likely have one and are reasonably cheap
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon ![]() |
#3 | |||
*Smart *** comment here*
![]() Anyways, try South Side Motor Wreckers, 678 South Rd Moorabbin 3189, (03) 9555 0677, they are ford specialits, and the bloke that served me was tops! |
Theres a few out eastern suburbs way inc:
Just Falcons in bayswater kilsyth area FTG Auto Salvage Ferntree Gully Pick a part in Kilsyth Hope these are help to you. There are heaps in the phone book call around and see what they got Paul |
![]() Join Date: Aug 2005
If you have only broken the GLASS you can buy that part with the plastic backing on it from Ford. You CANT buy a Coloured Mirror from Ford so you will either have to buy a NEW one in Black or search the wreckers for a same coloured one.
#6 | |||
![]() All fixed now, and roadworthy again! |
Hi all, rather than a new post, I thought Id follow on here. After my wife had an run in with a pole at the shops
![]() fef5000ngl from them on ebay. Is it much of a task to install? And has anyone else dealt with these guys before? Thanks Al |
You could get the whole thing from a parts salvage place for roughly the same cost, within ten bucks or so... and you wouldn't have the worry of dealing with ebay people.
However to answer the question, no I haven't dealt with them, though FTG and South Side Wreckers keep the mirrors in stock... The job itself is easy, shouldnt take more than about 15 mins. 1. There's three screws, they're behind a panel in the corner of your door (opposite side to where the mirror mounts to the outside of the car), remove that. I think there's one screw holding that pannel there. 2. That gives you accerss to the three screws holding the mirror to the car, remove these, WHILE holding the mirror, it will then just pull off (at this stage the connector for the electric mirror will pop out, just disconnect it, it's a run of the mill standard electrical clip, the new mirror will have the opposing end all ready on it). 3. Connect the electrical connector, pop the new mirror in its spot, screw it on, replace cover, all done!
1997 4.0L EL Falcon GLi Sedan Auto ---------------------- 2.5" Cat Back Mandrel Bent Exhaust to Two Lukey Sports Mufflers and a 3.5" Dump Pipe Lowered all round on King Spring Super Lows Tinted Windows, Pioneer MP3 Player and Audio System K&N High Flow Air Filter Mounted in Original Air Box Trip Computer NGK Sports Performance Leads NGK Sports Plugs Autotecnica Oil Catch Can
Last edited by GenesiS; 06-01-2006 at 07:39 PM. Reason: Should mention the electric side of the mirrors hey! |
#9 | |||
OzECruisers Treasurer
http://cgi.ebay.com.au/RH-Electric-D...QQcmdZViewItem |
Thanks GenisiS
Is the electrical connection inside the mirror assembly or inside the door ?
#12 | ||
Regular...with metamusal
![]() Join Date: Oct 2009
you have to take off the inside door cover to remove the mirror & the connection is pulled out or disconnected when the 3 screws are undone. how ever it's best to unclip the connector before removing the screws.
