#31 | ||
What’s a catalytic converter do
Community transport I work has 12 Hiace buses Parked in three locations One secure One not Thieves ripped off a couple of the cc s |
#32 | ||
4 users like this post: |
#33 | ||
What about a sensible reply
And not a Cannons Creek answer It off to the Pilbara penal colony for you very soon |
#34 | ||
Catalytic converter converts the nasties that come out the exhaust into less nasties when they go through it, uses shit like expensive metals to do it - they get poisoned/killed if your car runs too rich because of problems.
Been mandatory on unleaded engines since the mid 1980s, around the time leaded fuel got the *** on all new cars at the time. If we had mandatory yearly emissions tests in VIC I reckon 90% of the shitboxes on our roads would fail, including all of mine ![]() I think with diesel engines, particularly heavy commercial vehicles they had no emissions regulations until 2002 in Australia, thats why we hung onto mechanically injected diesels for so long in trucks, they eventually started getting phased out because competitors starting switching to electronically controlled engines to get one up over on each other in the mid 1990s, or late 80s in some cases. My ACCO being 1998 model is one of the last mechanically injected diesels before International switched to the ISC variation of the engine which has electronic injection. |
#35 | |||
praek tih kl jo kr
Ok the cat will give it a second burn, but will it burn it all when you are at full tilt, that I very much doubt, what comes out the tailpipe still contains the nasties, at a lower level than if they don't have a cat, sure, but it has not eliminated what a engine produces, as we still get some nasties out the tailpipe. Then the DPF burn, what crap is it spewing out when it does this, the way I see it the engine runs, the DPF collects the nasties, then you do a DPF burn down the track and it dumps all the nasties you have collected, you cant say that these are efficient and really don't let any of the nasties spew out?, sure they might be fine when the vehicle is new, but I doubt it after a few years. Just look at California where you have to have your vehicle smog tested, you wont see too many older cars on the road there. Last edited by prktkljokr; 04-02-2024 at 12:16 PM. |
#36 | |||
get enough temperature in the system to permit DPF burn off. They need to run on the highway and do that black sooty thing you’ve seen otherwise it gums up the works and ends up costing owners a lot more to fix. I hate thes modern diesels with a passion, they took a simple idea and made it so complicated that now it’s becoming just an expensive problem waiting to happen sometime in the future. The diesel cat converter is there for the urea adblue to reduce NOX, it does nothing for the diesel particles. In contrast, petrol cat converters look after all three HC, CO and NOX, while any particle filters if fitted are way cheaper to periodically change than anything on a diesel… |
#37 | ||
BLUE OVAL INC.
I thought all post 2018 Toyota diesels come with a manual DPF burn switch to prevent the issues they had with 2015-2018 vehicles subject to stop start or inner suburban driving?
#38 | |||
It's almost as if Melbourne needs something tangible around it, a wall perhaps, of something strong, like steel. A wall of steel. And not for any virus, either. Here's the latest, can't even work out the motivation: https://www.youtube.com/watch?v=oR65U0Z--OU
I6 + AWD |
#39 | ||
The other thing about the Toyota reporting, is that they have idled factories while investigating. How long will the waiting list on a new Cruiser get now?
I6 + AWD |
#40 | ||
1HDFTE For Life
The Silver Bullet - BJ74 Where the actions at Ontrack 4wd Club https://www.facebook.com/ontrack4wdclub |
#41 | ||
Official Toyota press release with list of affected models:
https://global.toyota/en/newsroom/co.../40376368.html
I6 + AWD |
#42 | ||
Is that the naturally aspirated one that takes about 30 seconds to reach 80 km/h...and will only go any faster downhill with a tailwind?
1996 XH Falcon GLi manual - Dynamic White 1998 EL Falcon Futura auto - Dynamic White 2023 SKODA Octavia RS - Moon White 1997 BMW E36 318i manual - Alpine White |
#43 | |||
Enjoy those downvotes ![]()
#44 | ||
https://www.carexpert.com.au/car-new...-waits-unclear
Cutting production now. Mazda gotta be enjoying that, as they have stock.
I6 + AWD |
