20-03-2016, 09:32 AM | #1 | ||
can someone please tell me where are the removal points on xr8 engine.
you have a hitch at rear of engine but nothing at front. i use bolt put thru chain into the exhurest nut thread?? worry bend the rocker cover?? please need advice thanks |
20-03-2016, 10:59 AM | #2 | ||
Irregular member
I removed a V8 recently and it had a removal loop bracket bolted into the first two header bolts on the passenger side. Maybe get one of those?
2000 AU II FAIRLANE 75th ANNIVERSARY - big and shiny My hovercraft is full of eels! Movie Car Chase of the Week: Gene Hackman driving a 1971 Pontiac LeMans to chase an elevated train in The French Connection (1971). |
20-03-2016, 11:13 AM | #3 | |||
wonder where i canget one from ?? |
20-03-2016, 04:47 PM | #4 | ||
Irregular member
Yes, on that side. I looked on eBay but cannot find anything. Maybe try a wrecker?
20-03-2016, 05:33 PM | #5 | ||
ive never seen them on them. interesting
20-03-2016, 05:41 PM | #6 | ||
These should fit http://www.ebay.com.au/itm/FORD-EB-E...oAAOSwbdpWXTjN
regards Blue |
20-03-2016, 05:51 PM | #7 | ||
Irregular member
That's it!
20-03-2016, 08:15 PM | #9 | |||
regards Blue |
20-03-2016, 08:19 PM | #10 | ||
RIP...
That's what I did.
I mentioned it so people with XR8's will know why they don't have them.
. Oval Everywhere... |
21-03-2016, 04:08 PM | #12 | ||
what way should i unbolt engine from Mount?
the bolt that goes thru mount and chassie ...or... two bolts thru mount on engine ? will be putting anthor engine in. thanks |
24-03-2016, 03:54 PM | #13 | ||
Irregular member
I undid the bolt that goes through the chassis, one spanner on the rear to jam it from moving, ratchet on the front. Then I removed the mounts from the engine once it was out.
I would say this would be the easiest way when putting the new engine in since they will help locate the engine to the chassis.
