Old 11-02-2014, 11:51 PM   #1
xr8 007
xr8 007's Avatar
Default Auto trans pan drain plug
Hi all.
Did a search but no luck. Just wondering if and how to install a drain plug to a auto trans on a au falcon? Thanks
Build Thread: BA XR8 with all the goodies.
fordforums.com.au/showthread.php?t=11247663
xr8 007 is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2014, 12:23 AM   #2
STINKY NINJA
Default Re: Auto trans pan drain plug
Dynomite performance do an alloy pan for the btr 4 speeder and it has a drain plug 299$
Nice looking bit of gear
STINKY NINJA is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2014, 10:10 PM   #3
speedzter
Drain plug kit about $25 on Ebay (but you probably knew that ).
Should be an easy thing to fit.
Thinking about fitting one myself.
Wonder it hasn't been shown on here before ?
speedzter is offline   Reply With Quote Multi-Quote with this Post
Old 14-02-2014, 12:31 PM   #4
xr8 007
xr8 007's Avatar
Thanks guys. Dynomite pan looks good but abit pricey as its only my daily driver.
Old 14-02-2014, 09:28 PM   #5
foxtrot3
foxtrot3's Avatar
Hi. Cant see a need for a drain plug on an auto, even if you drain the oil with a plug you still need to drop the pan to check for metal and clutch lining sediment as well as change the filter. Its not hard to pull the bolts out of one end or side of a pan and then loosen the next bolts as you go. Cheers MD
HI
I'M MICHAEL
Old 15-02-2014, 12:23 AM   #6
speedzter
It makes perfect sense to me to have a drain plug.
Definitely makes for a less messy filter change.
Old 15-02-2014, 07:31 AM   #7
foxtrot3
foxtrot3's Avatar
Hi. And once the pan is off it still drips oil from all over the valve body no matter how you drained the oil. the drain plug is just another place to leak and another thread for someone to strip. Cheers MD
HI
I'M MICHAEL
Old 15-02-2014, 08:16 PM   #8
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
You are both right I reckon...
I put them in my pans at least you drain most of the oil out before you remove the pan so its less messy once you unbolt it. Always use a bit of cardboard as well for drips. Beer carton is a good size. FYI I do most of my oil changes while they are hot so the less hot oil hits me the better.
They can leak as well, install them on side or somewhere where they cant get knocked off on a low speedbump etc.
For the OP, I weld them in myself from other bits of threaded metal I get from elsewhere. Basically you need a thin sheet of metal with a few mms of thread that you can fit a bolt into. You then cut and weld it into your pan. Use lots of threadtape on the bolt...
Jastel is offline   Reply With Quote Multi-Quote with this Post
