Old 09-01-2006, 05:04 AM   #1
niall.b
Posts: n/a
Default Cars with 9" diff
need a bit of info on what models of cars came equipped with the 9" limited slip rear diff. can anyone help?
cheers
Old 09-01-2006, 07:28 AM   #2
LTDHO
The one and only
LTDHO's Avatar
General rule is any factory fitted 351 pre XD.
I think disk was introduced in XBGT.
1992 DC LTDHO 360rwkw built by me
Tuned by CVE Performance
Going of the rails on a crazy train
Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
LTDHO is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2006, 08:12 AM   #3
niall.b
Posts: n/a
cheers, any pics available?
Old 09-01-2006, 10:38 AM   #4
rag top
rag top's Avatar
Are you after pics of the diff or pics of the cars?
Don't forget that a variety of american cars came with the 9 inch diff as well.
Current Rides:
2000 AU 5L XLS ute; 1970 Mustang project
Old 09-01-2006, 10:54 AM   #5
Josh_XC
i just put a new 9" diff in my car, XC 351, never looked back its awesome, although u will find urself sideways around conners more often, last night when it was raining, i was going around a conner at 15km/h and even went sideways then, OH THE FUN!!
Josh_XC is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2006, 10:58 AM   #6
BJ
Originally Posted by Josh_XC
i just put a new 9" diff in my car, XC 351, never looked back its awesome, although u will find urself sideways around corners more often, last night when it was raining, i was going around a corner at 15km/h and even went sideways then, OH THE FUN!!
I will tell you now Josh it can turn to S*&t very Quickly let me tell you. This was in the dry to. The clutch pack let go and this was the result. My advice is to watch your self.
BJ is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2006, 11:00 AM   #7
red_hotxr6
red_hotxr6's Avatar
Smile
How not to treat a ford..
red_hotxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2006, 12:36 PM   #8
ebxr8240
Performance moderator
ebxr8240's Avatar
All 9" in Aussie cars are LSD..Yep pre XD and fitted mainly with 351 engines..It varied though some 2v/ 2 barrel 351's had b/w diff...Disc brakes came out on XC...
Daily driver GTE FG..
Old 09-01-2006, 12:56 PM   #9
BJ
Disc brake rears first came out on late model XB's
Old 09-01-2006, 02:37 PM   #10
4Vman
4Vman's Avatar
Rear Disk brakes came out on Landau's in 72. All XBGTs which first came out in mid 73 had rear disks.
All 351 powered Fords (utes vans sedans limo's etc) had 9" rear's till the end of XC.
If you ordered an LSD in your non 351 powered XW or XY you also got a 9".
XA onwards had LSD BW's for non 351 powered cars.
335 S/C GT: The new KING of Australian made performance cars..
4Vman is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2006, 03:00 PM   #11
347Stroker
347Stroker's Avatar
XA RPO 83 coupe and Landau of 72 all had disc rear.
As said, all XB GT, Landau LTD and 351 Fairlane had Disc LSD 9"
There were open centre 9" cars sold here too, alot of XA XB utes, Fairmonts etc.
347Stroker is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2006, 03:03 PM   #12
4Vman
4Vman's Avatar
RPO 83's DID NOT have disk rear end, they ALL had drum _2:
Old 09-01-2006, 04:46 PM   #13
347Stroker
347Stroker's Avatar
Check your records good man, they definatly did, and were unable to have enough made in time for bathurst, so they also had them under the bum of the Landau, and argued with CAMS that they were essentially the same vehicle, being 2 door body shells, same 351 engine etc. It worked and the XA Goss ran and won in was disc rear equipped, so was Moffs....
Its the same with the on board jacking on the XA....
Ford were very cunning back when Marsden, Sancitonne and Gibson were throwing the orders...
Old 09-01-2006, 04:47 PM   #14
347Stroker
347Stroker's Avatar
I do believe that the 4 doors have drum rears though, but know that alot of the 2 doors definatly had them
Old 09-01-2006, 05:51 PM   #15
rag top
rag top's Avatar
Funny thing is the author of the thread is located in Bangor, N. Ireland. I don't think all this technical debate on what falcons had what 9 inch diffs really matters, when he asked what cars had 9 inch diffs...
Current Rides:
Old 09-01-2006, 05:58 PM   #16
smciner1
Detroit Locker Equiped TM
smciner1's Avatar
All XB GTs, including early 73 ones.
Apollo Blue 1974 XB Falcon GT, 557 HP
Blue Pearl 2004 BA FPV GT, 290 kW
Originally Posted by MRJUCY
Simple give the car a rev & have a listen a Windsor makes a sort of wheezy drone similar to an angry Hugh Grant when a Clevo will sound like Satan has woke up with a hangover & realized he is out of coffee & cigarettes
Falcon GT Club of Geelong.
http://www.facebook.com/FalconGTClubGeelong
smciner1 is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2006, 04:11 AM   #17
niall.b
Posts: n/a
cheers for the response, if someone could post both a car and a diff pic or two would be interesting. am looking for a straightforward replacement for my cossie that will handle a fair old bit of power too. and ИИИИ out action on the greasy roundabouts
Old 10-01-2006, 06:49 AM   #18
4Vman
4Vman's Avatar
Yes Ford Racing did some funny things, especially when it came time to lobby for homologation freedoms, ive got all the CAMS homologation docs for the RPO! but what they did to the race cars is not production car manufacturing!
I can assure you 100% that no RPO left the broady line with rear Disks, a friend did allot of research on this topic for the RPO story in AMC, including build sheet details etc, and he owns a VERY rare RPO coupe (with rear drums), i know of about 30 RPO coupes, all with rear drums too. Your right though about the Landau though, they tried to use the Landau as an excuse to allow the XA to race with disks, which was only done because the RPO didnt have rear disks! : .
Old 10-01-2006, 07:56 AM   #19
OzJavelin
OzJavelin's Avatar
"Cossie"? Cosworth Serria (spelling?) or something? If so, I'd think ANY 9" you find will need significant reworking to fit. The most narrow is probably from a sixties Stang (expensive) .. maybe a Stang 8" would be better .. or even some hi-po Japanese one? If the car doesn't weight much I doubt it needs a 9", more likely a strengthened stocker or something?
BTW: I've had 9" in a XB GS, XC GXL and 2x F100s. All of them gave be grief .. continuious bearings/seals problems. All the supposedly "weak" other diffs I've had (BWs, AMC20s, Mopar8.75") haven't given me any trouble ..
OzJavelin is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2006, 08:10 AM   #20
niall.b
Posts: n/a
Thanks Ozjavelin. im trying to get some background info at the moment. i have been told that there is a 9" diff that will slot straight into the Sierra rear beam. A friend of mine in Australia at the moment and given the info & viability, would source one for me and arrange shipping back home. Might all be a waste of time but does no harm to ask
cheers
Old 10-01-2006, 08:18 AM   #21
rag top
rag top's Avatar
Might be worthwhile contacting one of the race teams that used them or a derivative of the 9 inch diff in the sierra RS500.
Maybe contact djr through their website: http://www.djr.com.au
alternatively, get one cut down to suit?
Current Rides:
Old 10-01-2006, 03:42 PM   #22
jcxr
Tribal Elder
jcxr's Avatar
Contact Harrop Engineeringin Melbourne
jcxr is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2006, 12:01 AM   #23
outback_ute
Ute Forum Moderator
Contributing Member
outback_ute's Avatar
Dick Johnson was the first person to use the 9" diff centre in the Sierras when they were racing
outback_ute is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2006, 12:20 AM   #24
Gammaboy
Grinder+Welder = Race car
Gammaboy's Avatar
Beat me to it.
As the story goes, DJ couldn't keep even the race prepped factory diffs in his Sierra, so he developed and then homologated for Group A racing(no mean feat!) a diff that used 9" internals and bolted up to the factory mounting holes and used the rest of the sierra rear suspension (Although the Aussie Group A cars used alot of Harrop bits).
Finding one would probably be easier for you over in the UK because most of the Euro Group A cars wound up with the DJR designed and developed diffs in them (care of Andy Rouse i believe)
Here's DJ's Shell Sierra.
Piccy thanks to ZC-Cruiser's webby
Bigger version here:
http://www.ftw.com.au/cpg/albums/djr/DCP_0122.jpg
Funny, I just couldn't keep a BW in 1 piecce under my car (axles and spiders), however a friend of mine puts 500+hp through a Mopar8.75... he's bent the housing but its still in one piece... 2.75 ratio with a turbo'd Hemi6.
"No, it will never have enough power until I can spin the wheels at the end of the straightaway in high gear"
- Too much power is never enough....Mark Donohue on the Can Am Porsche 917.
Gammaboy is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2006, 12:56 AM   #25
Josh_XC
ahhh dont show me that lol. that even looks like my car an XC... thanxs hahhaa
Old 11-01-2006, 01:10 AM   #26
mik
mik's Avatar
xa gts were detroit lockers i think (correct me if im wrong)
Old 11-01-2006, 08:17 AM   #27
4Vman
4Vman's Avatar
Ok, Your wrong.. e
Traction lock LSD.
Old 12-01-2006, 09:48 PM   #28
mik
mik's Avatar
: woops
