17-05-2013, 03:43 PM | #1 | ||
I've been told I need a 5 point t50 bit to remove the steering wheel, would the t50 in that set be the part i'm looking for?
http://www.supercheapauto.com.au/onl...d=326051#Cross Thanks |
17-05-2013, 04:01 PM | #2 | ||
Pretty sure its the 6 point star looking one from memory.
i bought one of those packs of multi adaptor drill bits with about 30 bits. A little more expensive but so many more bits
17-05-2013, 04:05 PM | #3 | ||
oh really? might just ring ford to get a surefire answer. thanks mate
17-05-2013, 04:55 PM | #4 | ||
64 Deluxe 4 door
T50 Torx. 6 point. Buy a decent one if you plan on using it more than once. It also fits seat and seatbelt bolts. I would try and get a 1/2" one, rather then 3/8. Try Repco/Bursons or a tool specialist. Also a fair chance you will need a steering wheel puller, can be done without but its a PITA.
heres one http://gasweld-px.rtrk.com.au/594881....html?___SID=U
XM Deluxe FG XR50 BA Pursuit Ute |
17-05-2013, 07:47 PM | #5 | ||
not here much anymore
Should not require a wheel puller to get the wheel off. I have done it without.
2024 F150 XLT
17-05-2013, 10:46 PM | #6 | ||
I did mine without a puller and I changed the screws that hold the airbag on. I used screws with a 10mm head on them to replace, no more trouble.
19-05-2013, 12:32 PM | #7 | ||
Got Ghia?
6 point for the steering wheel. 5 point for the airbag. Pain in the **** to find.
If you get stuck for the 5 point airbag one you can cut a slot in a flat blade screwdriver tip and 'make it take it' as we say at work. But you will probably brake the screwdriver tip. i used 3 cheap tips to get the 2 screws out, and replaced them with regular bolts as above.
2007 BF MKII Ghia V8 - BA GT Exhaust| F6 Intake | Superlows | 19" GT-P's | 30mm Swaybar | - Sold 2002 AU2 XR8 Ute - Manual | Leather | Injected LPG | Pacemakers |
