Old 23-10-2012, 01:01 PM   #1
5.8
5.8's Avatar
Default AU Cigarette lighter fault
Hello all,
apart from the obvious, being a blown fuse, has anyone have any idea why my cigarette lighter would not be working in my AU. I am hoping it will be a common problem with someone offering an easy fix without having to run a new wire to the unit. Any ideas on where to start - after the fuse of course!!
5.8 is offline   Reply With Quote Multi-Quote with this Post
Old 23-10-2012, 06:28 PM   #2
foxtrot3
foxtrot3's Avatar
Default Re: AU Cigarette lighter fault
Hi. All ford and mazda lighter sockets since the 80's have had a thermal fusible link on the rear of the socket as well as the fuse in the fuse box. If you look on the back of the socket there is a short black wire going between 2 terminals and this will have melted inside the insulation, you just need to solder a short bit of wire to the 2 terminals to replace the melted one. Cheers MD
HI
I'M MICHAEL
foxtrot3 is online now   Reply With Quote Multi-Quote with this Post
Old 23-10-2012, 07:23 PM   #3
5.8
5.8's Avatar
Thanks MD, I'll have a look at that tomorrow.
Old 24-10-2012, 02:04 PM   #4
5.8
5.8's Avatar
Did all of that today MD and it's working fine now. Thanks for the help. Is there any long term danger replacing that wire for a normal wire? Should I be looking for a replacement lighter socket?
Old 24-10-2012, 07:15 PM   #5
foxtrot3
foxtrot3's Avatar
Hi. The link was made to blow if the plunger was held in for a long time ( children playing maybee). Other than Fords and Mazdas I dont think any other mob uses that base so I cant see any problem. Cheers MD
HI
I'M MICHAEL
