19-03-2011, 09:54 AM | #1 | ||
hi fellas, yesterday i removed the rear bar to remove the tow bar, this involved disconnecting the light plug..i just pulled it back through and left it in the boot didnt reconnect it and went for a quick drive the indicators were really dull and the climate control blinked with the indicators..obviously the wires were touching..quickly chopped off the end and she is all good now except no brake lights? wtf..last night i reconnected the trailer plug but still no good, the number plate and dash lights as well as rear park lights were working just no brake lights battery ended up flat so chucked it on charge, this morning i put the battery back in, everything ok same as last night just no brake lights..10 minutes later no park lights no rear number plate lights and nothing on the dash lights up!?
Have i ****** something up? would cutting off the end of the trailer lights cause issues like this? |
19-03-2011, 10:57 AM | #2 | ||
I know I could be way off the mark, but arnt all those lights connected to the same fuse? I'd check that first... Could have shirted something...
Edit: sorry, re read, didnt realise that they came back and then went away again... Sorrt man
AUI Ford Fairmont | Lowered with Kings | XR8 Leather Interior | XR6 Tickford Engine and Gear box| Last edited by Cadge; 19-03-2011 at 11:08 AM. |
19-03-2011, 11:13 AM | #3 | ||
with the brake lights I'd say it's a fuse with the rest look for an intermittant bad earth
[SIGPIC][/SIGPIC]
19-03-2011, 11:21 AM | #4 | ||
Is there just the one fuse? i swapped it with the horn relay and the fuse is fine, also unplugged the switch and bridged the connections and still no lights. Indicators and reverse lights work.
Looking like a trip to the auto elec.. |
19-03-2011, 01:36 PM | #5 | ||
yes just the one fuse get a test lamp and see if you have power on the switch
[SIGPIC][/SIGPIC]
19-03-2011, 02:02 PM | #6 | ||
hmm, that looks like its the problem, there is no power at the switch. Thanks mate, what would be the cause of that?
19-03-2011, 02:15 PM | #7 | ||
double check the fuses the best way is to earth the test lamp and turn the ignition on then check there is power at both sides of the fuse. the reason I recomend this is I have seen fuses that look fine but are open circuit
[SIGPIC][/SIGPIC]
19-03-2011, 04:34 PM | #8 | ||
Turns out it was a dud fuse..two of em, weren't visibly blow though. thanks for your help mate
19-03-2011, 05:01 PM | #9 | ||
Glad to be able to help often fuses that don't blow violently look ok
[SIGPIC][/SIGPIC]
19-03-2011, 05:16 PM | #10 | ||
You fixed it too quick , i wanted to come over and take a look ...
19-03-2011, 06:07 PM | #11 | ||
Thanks Daz mate next time i'll give you a buzz
