Old 04-12-2010, 08:08 PM   #1
XCwillo
Had Rep of GT-HO. Legit.
XCwillo's Avatar
Default So the police tried to defect my car tonight.
Just as i was pulling into work, he asked me to pop the bonnet, then went on to tell me that Breather pods coming out of my rocker cover are illegal, saying the engine isnt allowed to breath directly into the atmosphere?
Then went on to tell me that the tires i had on (BFGoodrich Radial T/A's) arent allowed to be used on my ute due to load ratings, and then when he checked the sticker to have a look, he looked puzzled and just told me to take it to bob jane and get them to see if they are alright :S
Since this is the first time i've had police try and defect my car, i was wondering if what he said is right?
I know that my XC being made in 1977 has a lot more leniance to regulations such as emissions ect
I'm back! Finally.
XCwillo is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2010, 08:15 PM   #2
SSD-85
AFAIK, Breathers on XCs and newer are illegal, due to emissions? Im probably wrong.
Obviously just trying to ping you for something on your older car & came up blank
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2010, 08:22 PM   #3
flappist
Which coppers? The traffic guys are pretty knowledgeable.
flappist is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2010, 08:24 PM   #4
pulpist
nope!
pulpist's Avatar
I'll bet he has a cousin workin' at Bob Janes
pulpist is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2010, 08:26 PM   #5
04redxr8
04redxr8's Avatar
+1 for this.
As for tyres, you will need to check the tyre placard, and compare with what tyres are fitted. If he didn't defect you for them, don't worry. If you start carrying a lot of weight, then worry.
04redxr8 is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2010, 08:27 PM   #6
Road Games
Road Games's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Replacement.
Which area were the traffic branch from mate .. they are normally pretty knowledgable these guys ...
Road Games is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2010, 08:32 PM   #7
GS608
As above a lot of traffic coppers are into modified cars and/or just cars in general and know their stuff.
GS608 is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2010, 09:02 PM   #8
jpd80
jpd80's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Thoughtful contributions to our community
White wall lettering is a "come fine me" magnet to coppers.
when I was younger we used to conceal the white lettering (turned inwards) and run our
cars as sleepers so as to avoid the cops, seems like Gen Y and Z don't know the rules..
jpd80 is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2010, 09:17 PM   #9
SSD-85
Anything that doesnt look & sound stock is going attract their attention. Given the cost of raised white lettering tyres these days, if youre just going to hide it, may as well save the cash and get plain tyres....
That's my Gen Y thinking.
Old 04-12-2010, 09:36 PM   #10
Tanksenda
Tanksenda's Avatar
Not sure about QLD but an XC ute in NSW are classed as a commercial vehicle and required to have 8 ply rated tyres. It should have a tyre plaque on the inside of the drivers door showing the size and rating of the tyre that should be fitted.
Tanksenda is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2010, 09:37 PM   #11
pottery beige
did you offer him discount from where you work bro....
pottery beige is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2010, 11:00 PM   #12
XB GS 351 Coupe
Breather on XC needs to recirculate into the air cleaner assembly so that oil fumes are extracted and burnt off, standard PCV system, your engine will thank you for it anyway.
Tyres need to comply to load rating of vehicle, and this is vehicle specific, does not matter if you decide to carry stuff in the back or not.
XB GS 351 Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2010, 01:04 AM   #13
XCwillo
XCwillo's Avatar
Cheers guys
Was just curious about it. He wasn't a complete A-hole about it and was pretty good with giving me some time to fix it all up.
And for everyone who asked im in mid queensland coast, Hervey Bay.
And my car looks and sounds nothing like stock
It has a lumpy cam sound (I doubt the old owners before me put a cam in, but if you heard it you'd swear it had one)
I'm back! Finally.
Old 05-12-2010, 02:23 AM   #14
xy500
Constant annoyance
The PCV side of it is taken care of by the pcv valve, the breather is for sucking air in, except for highest rpm or if your engine is cranking the blow by.
So it doesnt make 2/5ths of fa difference to crankcase ventilation, only to emissions.
GT Club - no longer for ford enthusiasts, now for fat old men who need air con and power steering for the maccas drive through.
xy500 is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2010, 03:06 AM   #15
jpd80
jpd80's Avatar
That's always been the case, it was just that 30 years ago most of the good
tyres had white lettering back then but mostly all 14" and 15" rim stuff.
Constant battles with XC and 5.8, anything with a cam was suspected of not
complying with emissions, you had to have crankcase ventilation all hooked
up so no pancake air filters, evaporative emissions and charcoal canister
had to be ther and hooked up. God help you if the Thermoquad carby and
EGR was replaced by a Holley.
Oh, not allowed to lower the front suspension by any more than 50mm
otherwise you might have clearance problems or get some bump steer...
Most guys used to use an XY width 9" diff in the back of the hard tops so
they could get 10" rims in there but the cops were wise and if you didn't
meed track that was a defect.
Sorry for the trip down memory lane and some of you other seniors out there know this song all too well....
Old 05-12-2010, 08:46 AM   #16
Cabbage
Cabbage's Avatar
He probably just wanted to check your ute out Willo and after he satisfied his curiosity he let you go. The key is if they pull you over be nice as pie and don't fail the attitude test, you'll get off more often than not.
Cabbage is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2010, 08:58 AM   #17
302 XC
jpd80,
Although there are road laws,theres always 1 law then 1 to contradict it
Track alteration by a minimal amount,then tyres no more wider than "X" amount from standard
Cant get ya 1 way,they try another
Willo,
Although everyone has an opinion as to whats allowable and not
Check out the QLD DOT website
Straight from the horses mouth
302 XC is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2010, 01:50 PM   #18
conordec
conordec's Avatar
you're right with that one cabbage.
i visit hervey bay once a year, and when i moved my GT up there, the first day i was pulled over.
the copper just wanted a chit chat, and gave me a heads up on stolen cars (ie, to be very, very careful).
not all boys in blue are members of the fun police ;) top guy really.
diamond blue xygt fairmont
silverfox red interior xygt fairmont
silverfox red interior xwgt fairmont
reef green xwgt falcon
lime green HT GTS Monaro 308 4 speed
reef green ZC Fairlane black interior
conordec is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2010, 10:23 PM   #19
JimNiki
71Mach1
JimNiki's Avatar
I would have thought that in today's world, the old classics on the road are far a few between and we've grown up now with families and behave responsibly... why would the cops even bother with so many "new" young idiots around...
We're not the enemy anymore...
roses are #FF0000
violets are #0000FF
all my base
are belong to you
JimNiki is offline   Reply With Quote Multi-Quote with this Post
