03-11-2009, 01:21 PM | #1 | ||
i an recently have problems with alot of smoke comming from the exhaust when i first start my 1991 laser up it has started since i have put new oil in the car i was wondering if it may be a prob with the oil or what else could it be??
03-11-2009, 04:19 PM | #2 | |||
Telstar TX/5 AX2
Cheers Wayne
FORD Telstar V6 2.5 Litre TX/5 AX2 - 1993 Build |
03-11-2009, 09:45 PM | #3 | ||
What colour smoke too? White, black, blue?
Current Rides: 2012 KK Jeep Cherokee Limited CRD - Still going strong 2019 MG ZS Essence 1988 RD Mitsubishi Colt GL - 59kW of Fury 2022 Kia Stinger GT |
04-11-2009, 12:56 AM | #4 | ||
it blow's alot of smoke when first started and for a little while when has been running for a while then eventually stops. and the colour is like a lite black/ gray kinda colour
thx for help |
04-11-2009, 01:22 AM | #5 | ||
As mentioned above, what is the grade of oil you put in it?
04-11-2009, 10:33 AM | #6 | ||
Telstar TX/5 AX2
You said that you put new oil in the car (engine) so I have to ask this question... How long had it been since the last oil change??
This could make a huge difference because if it had been a while and you had only topped it up along the way then my bet is that the valve stem seals have worn and the old oil may have been thick enough not to run (or seep) past the oil seals. What happens is when the engine is running the oil is spread very finely on the valve stems to keep them lubricated as with any moving part in an engine. When the engine is stopped the oil will run back down the valve stems and pool against the oil seals and when the seals are worn the oil passes by into the spark chamber of the head. Now sometimes you may have a few seals that are more worn than others which is why sometimes you might get a relatively clean start yet other times it's like somebody has set off a tear gas canister behind the car. If you think this may be the case then I would suggest that you take your car into a qualified mechanic and get them to sort it out for you. I'm pretty sure that it is a head off job and unless you have a good workshop with the right tools and a good aptitude towards mechanical work, you may not be able to complete the job. Cheers Wayne
