30-04-2009, 04:09 PM | #1 | ||
need somw help i have a au3 wagon and there is no spark in number one and six cylinder have replaced coil pack and still the same and also tryed dirrent spark leads does any one have a idea
black ed lowerd king springs 16" mags pioneer sound system. : |
30-04-2009, 04:33 PM | #2 | ||
howdy mate.going book gregorys handbook it would be fault code 215,failed to ignite cylinders 1 and 6.check battery voltage at terminal(red/dark green wire).is the replacement coilpack in good order ie seen running.with engine running their should be 1 to 2 AC volts present.check wiring connectors are in good nik as well.it can be a ecu related issue as well.it has individual circuits 4 each cylinder.check for corrosion around ecu.good luck
01-05-2009, 12:36 PM | #3 | ||
i put new coil pack in today and still same thing
01-05-2009, 02:12 PM | #4 | ||
would it be a sensor
01-05-2009, 03:44 PM | #5 | ||
It could be
Personally -I would be reseating all the connectors I could including the ECU. This is just pulling them off and then back on (ignition off) - 1 at a time I would even do the battery connections inc fuses/relays etc to start with No cost, just a bit of time - do 1 at a time. When you do the battery - make sure you have the PIN for your radio first then neggative off first and when putting it back on, negative last (so pull neg then pos and when connecting again, pos then neg in that order) |
06-05-2009, 09:07 AM | #6 | ||
we found the problem ended taking it to ford and found out the ecu was stuffed we brought a second hand one for $110 from wreckers and swap it over ford said its back to normal and has a bit more grunt now
06-05-2009, 09:31 AM | #7 | ||
: problem fixed with extra grunt,if only it always worked out this way. :
06-05-2009, 09:34 AM | #8 | |||
Walking with God
GK
