Old 24-06-2007, 01:02 PM   #1
private9
www.TUFFCARPARTS.com
private9's Avatar
Default Will this work on my AU I6? (Crane MSD ignition setup)
Hi All,
Pretty sure the answer's no here, but I have it lying around, so thought I should check.
I have a Crane Fireball Hi-6 Ignition system and I'm wondering if this will work in my AU. It was previously in an EL Falcon (single coil application).
I know that with the AU being a multi coil setup, obviously the LX92 coil pictured won't be of any use in the AU (multi-coil), but even after searching the Crane website, I can't quite establish if I can actually use the Hi-6 Ignition system.
I normally view such things as useless in a modern multi coil equipped car, but since I have it lying around, I thought I'd at least give it a try if it's able to be used.
Thanks,
Justin.
private9 is offline   Reply With Quote Multi-Quote with this Post
Old 24-06-2007, 01:21 PM   #2
Christiaan
Tuned @ Pitlane Frankston
Christiaan's Avatar
I wouldn't think you'd notice much of a gain from just upgrading the ignition system. Usually these systems are reserved for big power/boosted applications?
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
Christiaan is offline   Reply With Quote Multi-Quote with this Post
Old 24-06-2007, 01:29 PM   #3
private9
private9's Avatar
Yeah, I'm not expecting any difference at all actually, but thought that since I have it, I may as well give it a go if it fits, and then I'll probably flog it off, or hide it in the shed for that old-school project that I have in my dreams!
When I saw this thing in my EL, I thought to myself, what kind of person spends hundreds and hundreds on a hipo ignition system for a basically stock EL 6.
Old 24-06-2007, 01:41 PM   #4
LUXO_8
windsor user
they were probably planning to turbo it.....
Old 24-06-2007, 02:20 PM   #5
private9
private9's Avatar
Actually, now that you mention it, that's exactly what he was planning. He already had the turbo kit too.
Old 24-06-2007, 04:36 PM   #6
Stav
Smile
Stav's Avatar
I dont think it is suited to the au six cylinder as we have multiple coil packs.
Stingray Car Security ph 0414445444
Single din radio fascias for fg to fgx fords Australia wide .
FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/
Site Sponsor See Sponsor Stingray Car Security 😍👌✌
AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again
Old 24-06-2007, 04:51 PM   #7
LUXO_8
windsor user
good point..... it'll only work on cars with a single coil and a distributor....... so no it wont work on the AU
Old 24-06-2007, 04:55 PM   #8
private9
private9's Avatar
Thanks guys. Well I guess I won't be using it then!
Old 26-06-2007, 12:13 PM   #9
private9
private9's Avatar
Well, just had it confirmed 100% - won't work on the AU!
Old 26-06-2007, 02:11 PM   #10
FGII-XR6
FGII-XR6's Avatar
the AU with it's coil packs use 3 chanels for coil signal so if there was any chance it would work you would need 3 of them
Old 26-06-2007, 02:13 PM   #11
private9
private9's Avatar
Well at $600 odd new, I only have $1200 more to go!!!
Old 26-06-2007, 03:15 PM   #12
FGII-XR6
FGII-XR6's Avatar
if thats all thats stoping you go for it
Old 26-06-2007, 03:25 PM   #13
private9
private9's Avatar
he he! No thanks! Was only going to try it because I had it - I'm not THAT keen!
