07-12-2006, 04:41 PM | #31 | ||
Its Resonating!
Ive got little bits of pvc pipe in my intake (to connect things etc...)
I found they warp, get smaller and sometimes falls apart Metal intake coming |
07-12-2006, 04:55 PM | #32 | ||
yeah?? mine hasnt melted.
07-12-2006, 05:18 PM | #33 | ||
I think most people saying it will melt or catch fire, are not talking from experience
07-12-2006, 05:25 PM | #34 | ||
Just cruisin
Good idea with the plumbing pipes I thought of doing it myself. I ended up just cutting most of the first section of intake pipe off, then removing the adapter thing that sits on the air box and put the bolts back in the holes. And then connected two short lengths or this tubing stuff (found it at work) with some silocone hose. All up $10
___________________ BA LTD 5.4 |
07-12-2006, 05:25 PM | #35 | |||
Was V6corp
Just common sense?
Car: 99 AU I Forte Sedan Colour: Blue Engine Mods: K&N Pod in a XR8 Pod Box; Performace fuel pump; 2 1/2" Exhaust Planned Engine Mods: ; Extractors; Tickford CAI; Twin Mufflers; Shift Kit; Hi-Stall; Cam; ECU Flash Bling Mods: Tinted Windows; JVC CD/DVD HU Planned Bling Mods: TS50 Front; High Series bonnet; Rebel Skirts and Rear Bar; SL Springs; Clear Side Indicators; Rear Spolier; Mags |
07-12-2006, 05:36 PM | #36 | ||
Audi S3
what about ABS plastic tubing?
07-12-2006, 06:15 PM | #37 | ||
Back in a Blue Oval
we use a heat gun at work to bend the PVC we use, and it doesn't take much time or contact before it starts to get soft
'13 Territory TX Diesel RWD. The Family Bus '08 Mitsubishi Pajero. The Off-road Machine |
07-12-2006, 06:21 PM | #38 | |||
Last warning
i had some PVC piping in my engine bay, it warped. seems i'm not the only person whos had this happen either.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
07-12-2006, 06:22 PM | #39 | ||
If its fouling against something you'll have issues, but with enough clearance, it will be fine. So far I've heard people doing it with no issues, and only people who havn't saying there will be issues
08-12-2006, 02:17 AM | #40 | ||
there has to be A plastic pipe that is made of the same material as the stock item!
as the stock one is plastic.. what kind of plastic is it made of? i like what DVL40L has done with his.. a bit more blue in the engine bay and a nice big pipe! and looks like it will probably stand up to a bit of heat/abuse..
09-12-2006, 02:01 AM | #41 | |||
Highway Taxi
Close only counts in Horse Shoes & Hand Grenades. :evil_laug |
17-12-2006, 12:15 PM | #42 | ||
ok, so on AUfalcon.com, it says to get the 90mm pipe for between the airbox and intake at the motor, what is the recommended piping to use... I want to have a go at this myself, but after this thread am VERY confused as to what I should use...
17-12-2006, 04:29 PM | #43 | ||
Formally Kia Chaser
Supercheap are now selling bent metal intake piping for like 20-30 bucks per peice. They have 180, 90, and 45 degree bends, and then just plain straight peices...
Kia Grand Carnival (2006) Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw HSV Clubsport R8 VY (2003) Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
17-12-2006, 07:36 PM | #44 | |||
SII XR8
I know I haven't. The hot air gun at the same temperature would burn holes through your hand. 90mm stormwater pipe and fittings on the other hand are the lowest quality plumbing products available... 80mm sewer class pipe and fittings are of much higher quality and should be much more durable, will cost a bit more however. |
