Old 08-06-2006, 11:32 AM   #1
HLC
Audi S3
Default Just did LED conversion in the power window switches. but...
i used these instructions here, http://fordforums.com.au/vbportal/mo...article&id=203
after following them i had to change my lights around a tad to get them to work properly, using 1000mcd blue LED's not that that makes a difference.
anyway, all my lights work, but when i put the button back on the drivers side rear door, the light goes off, and only turns on when you push the button to put the window up. i swapped lights, everything, and now the light doesnt turn on at all with the button on, but with the button off it works... any ideas?
ill post some pics later. they look good.
Old 08-06-2006, 11:39 AM   #2
AWD Chaser
Formally Kia Chaser
AWD Chaser's Avatar
Sounds like a loose contection, or a short....
Kia Grand Carnival (2006)
Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw
HSV Clubsport R8 VY (2003)
Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
AWD Chaser is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2006, 11:42 AM   #3
HLC
Audi S3
yeah i cant figure it out, cause if i take the button, as in the bit you push/tilt, it works... and when i put it on, there is not contact between the button/light... so ive no idea.
Old 08-06-2006, 11:47 AM   #4
XR6-VCT-2000
Fantastic Plastic
XR6-VCT-2000's Avatar
yep sounds like a short/or bad connection . By the way, the MCD is the brigtness of the LCD , the higher the MCD the brighter they are .
:eclipsee_
Old 08-06-2006, 11:54 AM   #5
HLC
Audi S3
yeah, i read that in the tutorial, and the guy at jaycar told me.
Old 08-06-2006, 02:56 PM   #6
XR6-VCT-2000
Fantastic Plastic
The original l.e.d's , were they actually a coloured l.e.d or did they have like small plastic coloured covers over a clear/white l.e.d ?
:eclipsee_
Old 08-06-2006, 05:09 PM   #7
Stav
Smile
Stav's Avatar
Its got nothing to do with a bad connection.The power window alternates between power and earth.You are probably losing earth when you hit the switch because power is going through.
Old 09-06-2006, 08:01 AM   #8
HLC
Audi S3
no real way i can fix that? cause now the light doesnt work at all in the switch... unless i take the button/bit you press off. maybe ill get you to have a look at it next club meet. cheers Stav!
Old 09-06-2006, 06:40 PM   #9
chief
FTF Club Moderator
chief's Avatar
I wondered if you were going to do it, to complement the thousand other LED's you have. jokes. I don't know what the problem would be apart that it could be earthing. It would certainly look good. What colour did you choose?
Albert Einstein:
Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom.
(It is more difficult to alter a preconception than split an atom)
Falcon Tickford FPV (FTF) Car Club of NSW
Fords in the Park 2010
I use and recommend Stingray Car Security.
http://www.stingraycar.com.au/
chief is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2006, 07:01 PM   #10
HLC
Audi S3
blue of course, like the rest of them :evilking: im not finished either! got plenty more ideas
Thread Tools
Display Modes
