Old 26-01-2014, 12:57 PM   #1
mcfly94
mcfly94's Avatar
Default AU2/3 Front Brake Upgrade.
Hey guys so I have been through a few threads on brake upgrades.
From what I read ba calipers are different to au calipers and are slightly better.
But are ba calipers different to like bf xr8/xr6t calipers or is it just the mounting bracket to suit 322mm rotors?
Ive read the difference between stock au2/au3 and standard ba is not really worth it and for a bit of extra cash the 322mm upgrade would be much better.
I found this little kit on ebay.
http://www.ebay.com.au/itm/FORD-FALC...item417adee2c5
So would I just need to source standard ba calipers? and this kit would allow me to run the 322m discs?
mcfly94 is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2014, 02:38 PM   #2
hales231271
hales231271's Avatar
Default Re: AU2/3 Front Brake Upgrade.
To use this kit on your AU s2-s3 you will also need a set of BA front callipers and a set of BF xr8/xr6t front brake lines.
The BF xr8/xr6t lines are longer.
I have the BF xr8 front set up on both my AU3 xr8 and AU2 xr6 ute.
Great upgrade.
Dazza
hales231271 is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2014, 12:00 PM   #3
mcfly94
mcfly94's Avatar
Alright thanks!
Old 27-01-2014, 03:08 PM   #4
gassa
l have bf twin pot calipers and hoses if needed
gassa
gassa is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2014, 06:36 PM   #5
mcfly94
mcfly94's Avatar
Anyone know whats needed to fit the bf premium brakes to the au, the 325mm disc?
Old 12-02-2014, 10:24 PM   #6
gassa
[just bolt them on
gassa
Old 16-02-2014, 07:49 PM   #7
bluestripes
Q - CAR
bluestripes's Avatar
Im running BA premium XR8 brakes on my 17in rims. And they fit with about 5 mm clearance and i needed to remove some of the inner wheel alignment weights. I also used the BA hoses.
Great brakes - same as PBR premium or Brembo 4 pot.
AU FORD STROKER
347 Windsor Stroked; (10:2.1) / TFS 190 heads / TFS R Series 90 manifold / Accufab 85mm Race TB / 90mm Lightening MAF / K&N 90mm pod CAI / FTI custom cam (230-236 @ 50) / Bosch 36lb inject / MSD coil + leads / ASR 8lt sump / Mcleod RST Twin Plate Clutch / Pacemakers PH4006 + 3" single exhaust / BA Premium brake pac / Pedders Xtreme coil over shocks / 30mm Whiteline sway / 3.45 LSD / Custom FG bonnet / Ghia interior upgrade / Enkie Rims - staggered / Quarter Horse tuned.
bluestripes is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2014, 08:06 PM   #8
mcfly94
mcfly94's Avatar
yeah I definitely don't want to remove any of the wheel weights
Thread Tools
Display Modes
