Old 26-05-2012, 08:14 PM   #1
TheSly1
Default How do i fix this oil leak.. please?
hey guys got a s2 au falcon dedicated gas.. 6 cyl
ive got a fairly constant oil leak and i tracked it down today to one of the bolts on the front left pulley on the motor (the one next to the power steering pump pulley) when i pulled the bolt out, oil came out (of course)
So i compared it against a mates one and he has the same bolt and same setup...
looks to me its a bush or such and the bolt seals up on that, but i cant work out why its leaking..
anyone had this issue?
TheSly1 is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2012, 08:44 PM   #2
hagarone
hagarone's Avatar
Default Re: How do i fix this oil leak.. please?
Oil leaks are a pain. there is a seal in there. I got my one fixed about a month ago.
hagarone is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2012, 08:44 PM   #3
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
When I mucked around with the timeing chain tensior, I undid this blot. I put some gasket goo on it to help resell it when I finished. No leaks
UK
Uncle_Ken is online now   Reply With Quote Multi-Quote with this Post
Old 26-05-2012, 08:45 PM   #4
Gaz
Got Ghia?
Gaz's Avatar
Just make sure that bolt and the two above are tight. Is it leaking from behind the head of the bolt or the bracket?
Just put a bitta silastic on it and tighten it up.
2007 BF MKII Ghia V8 - BA GT Exhaust| F6 Intake | Superlows | 19" GT-P's | 30mm Swaybar | - Sold
2002 AU2 XR8 Ute - Manual | Leather | Injected LPG | Pacemakers
Gaz is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2012, 08:48 PM   #5
Kryton
Kryton's Avatar
Must be an AU thing.
Mines leaking there too.
Old 26-05-2012, 08:53 PM   #6
TheSly1
yeh the only thing i could think was maybe its a bit askew, so I might try loosen the 3 bolts and then evenly tighten them up.. i tried a bit of silastic today but it leaked still..
gaz to answer ur question it appears to be leaking at the bolt head.. i might just pull the whole bracket off again and reset it.. im sure its that simple.
Old 26-05-2012, 09:24 PM   #7
TheSly1
hey mate can you tell me about this seal? or anyone else know?
Old 26-05-2012, 09:31 PM   #8
Uncle_Ken
Uncle_Ken's Avatar
If its the long thin blot it has a small O ring at the end
UK
Old 26-05-2012, 09:36 PM   #9
Mechan1k
Mechan1k's Avatar
It's not from the cam chain tensioner behind the power steer pump bracket is it????
It's definitely a common AU trait ... and they bleed out from there like anything.
Old 26-05-2012, 09:39 PM   #10
Uncle_Ken
Uncle_Ken's Avatar
Thats where mine was coming from
UK
Old 26-05-2012, 10:32 PM   #11
TheSly1
nah definatly not, been there done that, but i ran it for 5 mins after id cleaned it up and it was dripping from just below the bolt lip..
reading up on another post looks like ill pull it all off and use some orings to help seal it up..
http://www.fordforums.com.au/showthread.php?t=11336109
Old 27-05-2012, 10:14 AM   #12
_Ben
_Ben's Avatar
Any idea how much a mechanic would charge to fix this? I've currently got this problem, but I have other things to deal with so I can't really do it myself atm.
_Ben is offline   Reply With Quote Multi-Quote with this Post
Old 27-05-2012, 01:17 PM   #13
mik
mik's Avatar
if your losing lots of oil it can also be leaking from the timing chain tensioner plug/bolt/adjuster,
and it can deceptively look like it`s coming from elsewhere, if sealing up the bolt/s on the front does`nt help i`d be having a good look at the tensioner o` ring.
Old 27-05-2012, 06:51 PM   #14
_Ben
_Ben's Avatar
Since you can't edit on here: I managed to get access to the bolt, did it up a bit and the oil leak has stopped. Not a permanent solution, but it solved the side effects :P
Old 27-05-2012, 06:56 PM   #15
mik
mik's Avatar
well done !
Old 27-05-2012, 08:47 PM   #16
Kryton
Kryton's Avatar
Did mine today as well.
Had been leaking for a while buy the looks of things.
The bolt was a whole 1/2 turn loose as well.
Bit of a clean and some gasket goo, and so far its all good.
Ill keep an eye on it though.
Old 19-03-2013, 06:12 PM   #17
rowan194
I've just been investigating a leak (first time since I bought the car in 2005 that it has spotted my driveway :( ) and it seems to be coming from the same place as the OP's bolt. Top two are tight as, but the third one, arrow in the OP pic, went half a turn without much trouble. Will see if that fixes it, although I'm probably being a bit optimistic. Why do these bolts go all the way through to the oil gallery???
rowan194 is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2013, 06:22 PM   #18
Uncle_Ken
Uncle_Ken's Avatar
Why is the Pope Catholic?
Never let logic get in the way of car and engine design.
Hope the fix works for you
UK
PS Not having a go at Rowan or the Pope.
Old 20-03-2013, 01:58 AM   #19
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
No.4 Permatex gasket cement is your friend. Dip the thread in it or paint it on the thread with the brush in the bottle when you put the bolt in and your leak should go away.
Bushbasher
MINE- AUII Forte
Thread Tools
Display Modes
