21-11-2010, 09:23 AM | #1 | ||
Back in black
G'day fellas,
My XR8 has had this issue for years. Some days it OK(just a little) then others it's not good. The go fast pedal has to be forced down to get it to go. It seems that there's a lot of resistance when you ease off to zero acceleration then try to put your foot down. You can't ease on the power. You have push it harder then she launches. Every other way it feels normal. Doesn't get stuck on. Any ideas? Have tried a few things. All moving points lubed in some way from pedal to throttle body. Inside throttle body cleaned.
Black Mac TE50 S3 NO: 106 Little Mac AU S2 XR8 Bite the snake before it bites you! ______________ _.__ /________...\ _.._(___\\___//___) .._..(O...\____/...O) |
21-11-2010, 09:30 AM | #2 | ||
Maybe the throttle cable is stretched or kinked
Welder/Fabricator at Beaudesert Exhuast Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors |
21-11-2010, 12:47 PM | #3 | ||
Lost Boost Gained Class
Try changing the throttle spring on the throttle body and see if that fixes it
2006 BF Fairmont Ghia
2001 AU Falcon |
21-11-2010, 01:09 PM | #4 | ||
maybe spray some crc with the the spray tube down inside the cable and see if any change.
23-11-2010, 06:17 PM | #5 | ||
any updates?
23-11-2010, 06:58 PM | #6 | ||
Back in black
No not yet. Wont even see the XR til the weekend. Will have another look then.
23-11-2010, 08:58 PM | #7 | ||
I'd check teh action of the cable through the firewall, and the action at the TB. My guess is something is fouling the linkage at the TB end.
23-11-2010, 10:10 PM | #8 | ||
Check your cable for broken wire strands jamming in the outer sheathing.
26-11-2010, 05:43 PM | #9 | ||
Back in black
Copy both thanks to all checking tomorrow
27-11-2010, 06:25 PM | #10 | ||
So how'd you go Dave? Sorted?
27-11-2010, 09:59 PM | #11 | ||
Formally kotevski22
Replace cable.
12-12-2010, 03:05 PM | #12 | ||
Dave,
I have the same issue mate, TB cleaned/cable and mech compents lubed, spring replaced, even had a machnic try to re run the path of the cable (bad move, back to normal now). I seem to get this problem more so when the car is cold, eg in the morning or very late at night. Let us know how you go, and if i get it fixed in the mean time will give you a post |
03-05-2011, 06:41 PM | #13 | ||
Back in black
Weird stuff hey. Replaced the harmonic balancer due to car dying and vibrating at low revs. The sticking throttle has dissapeared with the new balancer. Low down power now is like a new car. It must have been struggling down low for ages and somehow causing the sensation of a sticking throttle. The XR8 got the left top engine mount plate replaced when two new replacement bolts were being put in and that too has improved the smooth feel. I forgot what the car felt like when new. Very
03-05-2011, 07:51 PM | #14 | ||
V8 AU Fairlane
hey mate i just saw this thread i had the same feel in the fairlane. I replaced the harmonic balancer got a service done and all is good again.
Thread Tools | |
Display Modes | |
