Old 22-05-2007, 03:39 PM   #1
markxr6t
Default PCM Code Sticker
Hi all
I'm relatively new here and have an AUII XR8 220. I'm getting a new exhaust on Saturday and have sent my Flash Tuner back to CAPA for unlocking and installing of a generic tune. Thing is, they want the PCM code, a 4 character code, which is apparently on a sticker on the PCM.
I've found the PCM in the LHS passenger kick panel, but its metal bracket is riveted in and I can't remove it. No sticker is obvious.
1. Does anyone know EXACTLY where the sticker is so that I could maybe find the code with a torch and dentist mirror?
2. Any other alternatives to drilling out the rivets in the bracket to drop the PCM and find this darned sticker? I've called a Ford dealer with my VIN, but they can't help.
Thanks
Mark
PS - When all this is done, I look forward to reporting my results of a custom exhaust and generic edit!
markxr6t is offline   Reply With Quote Multi-Quote with this Post
Old 22-05-2007, 07:31 PM   #2
xr8ute
Back on the road
xr8ute's Avatar
Its on the plastic connector that the loom plugs into.
I drilled out the rivet, and then ran a tap through it for a 1/2" (i think?) bolt.
AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute
5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor.
Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash.
xr8ute is offline   Reply With Quote Multi-Quote with this Post
Old 22-05-2007, 07:46 PM   #3
ratter
ratter's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Shares his in-depth tuning knowledge with the forum, very helpful. Contributor: For members who make a contribution worthy of recognition. - Issue reason: For his indepth tutorial on adding borders to photographs
If you can get to a capa dealer with a data logger, they can access the code via the obd2 port.
What are Capa charging you to unlock it?
Pit Lane Performance
20 Rosella St Frankston 03 9783 8122
Authorised Streetfighter, Pcmtec , SCT & HP Tuners Tuning Agent,
ratter is offline   Reply With Quote Multi-Quote with this Post
Old 22-05-2007, 09:27 PM   #4
markxr6t
Thanks for your replies!
I found the code ("12RB") on the bottom of the PCM with a mirror which means I won't have to drill out the earthing rivet (photo attached of where I found the sticker - hopefully it'll help someone else).
CAPA is charging me $75 to unlock and $75 to put in AU xr8 220 generic tunes. Good value and CAPA are good to deal with too.
Some local performance shops were going to charge $175 just to send it back to CAPA directly to unlock (ie $100 for posting it!)
Furthermore this dispels that a Flasher box locked to another car's VIN (my previous XR6T) needs to be sent back to SCT in America for unlocking. Still got 3 lives left for my BF XR6T (when I get it) and beyond!
Mark
Thread Tools
Display Modes
